2D stabilize node: Render Quality has no effect
b2.63 r49878 Windows 32 bit
2D stabilize node, when changing the Filter type from linear to bicubic, there is no change in quality. There is same amount of aliasing for any type. This was not the case when 2D stabilize was introduced.
Noticeable on any rotation amount used to stabilize an image.
I don't see that the node->custom1 is read anywhere. This needs to go to a SetSamplerOperation perhaps we missed this one. Will check svn
David, where do you change the filtertype of the stabilize node? I do see it in the rotate node and in the transform node, but not in the stabilize node.
Regards,
Jeroen
Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.
Jeroen Bakker (jbakker) changed the task status from Unknown Status to Resolved.Sep 11 2012, 12:26 PM
