Problem with "Ghost" in the "Glare" Node in Compositor
I am using Blender 2.63 version 49977 for Linux Ubuntu 64-bit. When I use the compositor to create a "ghost" in my scene, the "ghost" effect is pixelated. It is not smooth like before. I have also tried rendering my scene in the second test build and I see the same problem.
This is the link to a picture of my rendered scene.
http://www.pasteall.org/pic/36694
Hi Sylvanus,
Could you send me the settings you are using (node setup, glare node settings) Otherwise we cannot help you.
Best regards,
Jeroen Bakker
Hi. I can send you my blend file. Here's the link below.
http://www.pasteall.org/blend/16010
Fixed in revision 50079.
Jeroen Bakker (jbakker) changed the task status from Unknown Status to Resolved.Aug 21 2012, 12:45 PM
