Mixing with translated images in compositor produces garbage strips for each tile
Mixing translated images with compositor produce garbage strips for each tile. Looks like some node determines depending area of interest wrong. Please see the attached file.
Tested with r50409, Ubuntu 12.10 64-bit.
This issue was fixed for the "combine channel" nodes. Mix node also need to have the same patch.
Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.
Jeroen Bakker (jbakker) changed the task status from Unknown Status to Resolved.Sep 11 2012, 6:57 PM
