windows vista 32 bits
but also on other system !
2.63 SVN 50696
and also in 2.49 !
to see the bug just render it
and the front door refuse to render !
i imported these objects from a 2.49 file
and at first it was rendering normaly
then i added a second material to the front door ect.
now when i render this the front door does not render !
it looks ok in outliner visible !
so this is a bug to render some objects in 2.63 and 2.49 too!
2.49 bug also
i also save 2.63 file as legacy then opened up in 2.49 but it also did not render !
thanks
Comment Actions
The objects that are not appearing rendered have duplifaces enabled, apparently for no reason. According to the wiki parents and children in a duplication are not rendered, so this seems to be working as expected. Just set duplication to none in Object settings to get the mesh to render normally.
