Camera borders gets corrupted after selecting objects in 3d view.
Camera borders gets corrupted when selecting objects in 3d view. Have to restart Blender to get them sane again...
This is on Ubuntu Breezy PPC.
ATI Technologies Inc Radeon R250 Lf [Radeon Mobility 9000 M9] (rev 01)
anders@jupiter:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGIS_multisample, GLX_SGIX_fbconfig
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group
GLX version: 1.2
GLX extensions:
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI R200 20041207 AGP 1x TCL
OpenGL version string: 1.3 Mesa 6.3.2
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_compiled_vertex_array, GL_EXT_convolution,
GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_histogram, GL_EXT_packed_pixels, GL_EXT_polygon_offset,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_APPLE_packed_pixels, GL_ATI_blend_equation_separate,
GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_texture_rectangle, GL_NV_texgen_reflection, GL_OES_read_format,
GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x28 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x30 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Logged In: YES
user_id=103
some gfx cards (or drivers) have problems drawing dashed lines... usually it goes away when you upgrade/downgrade drivers. This has been reported before.
BTW: It works OK for almost all blender configurations... doubt if this is a bug in blender.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:15 AM
