object render error when appending it using groups
hi,
I was trying to append a Group which contains my model and rig from another file in to the main file but on rendering it causes errors on the surface of the mesh in BI on linux/Centos 6.3 32 bit. It could not be rectified even after changing the materials, normals, textures. I am uploading two files one contains simple objects in a Group and other contains a simple code to append the group in to main file.
Your script exports everything twice, the group and the originals. The errors you see here is typical for perfectly aligned faces on same place.
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Oct 20 2012, 6:54 PM
