Blender 2.64x will not launch on Mac Mini with OSX 10.6.8
Neither Blender 2.64 nor 2.64a 32-bit will launch under OSX 10.6.8 running on either of my 32- Mac Minis.
Blender 2.63a 32-bit launches without problems on my 32-bit machines.
Blender 2.64a 64-bit launches normally on my 64-bit Mac running OSX 10.6.8.
Only the 32-bit version appears to be affected.
Included below are the system-info.txt file (generated by Blender 2.63a, since 2.64 will not launch), and the Apple diagnostics file generated when Blender fails to launch:
SYSTEM-INFO.TXT:
= Blender 2.63 (sub 0) System Information =
Blender:
version 2.63 (sub 0), revision b'46461'. b'Release'
build date: b'2012-05-16', b'20:53:38'
platform: b'Darwin:64bit'
binary path: '/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/blender'
build cflags: b'-DWITH_QUICKTIME -isysroot /Developer/SDKs/MacOSX10.5.sdk -mmacosx-version-min=10.5 -arch i386 -pipe -funsigned-char -DNDEBUG -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -m32 -DGHOST_COCOA -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE'
build cxxflags: b'-isysroot /Developer/SDKs/MacOSX10.5.sdk -mmacosx-version-min=10.5 -arch i386 -pipe -funsigned-char -isysroot /Developer/SDKs/MacOSX10.5.sdk -mmacosx-version-min=10.5 -arch i386 -DNDEBUG -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -m32 -DGHOST_COCOA -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE'
build linkflags: b'-mmacosx-version-min=10.5 -Wl -isysroot /Developer/SDKs/MacOSX10.5.sdk -arch i386 -fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Cocoa -framework Carbon -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework OpenAL -m32 -framework QuickTime'
build system: b'SCons'
Python:
version: 3.2.1 (default, Aug 5 2011, 20:41:36)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
paths:
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/scripts/addons'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/scripts/startup'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/scripts/modules'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/python/lib/python32.zip'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/python/lib/python3.2/'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/python/lib/python3.2/plat-darwin'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/python/lib/python3.2/lib-dynload'
'/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/scripts/addons/modules'
'/Users/jiw2/Library/Application Support/Blender/2.63/scripts/addons/modules'
Directories:
scripts: ['/Applications/Blender/blender-2.63a-release-OSX_10.5_i386/blender.app/Contents/MacOS/2.63/scripts']
user scripts: None
datafiles: '/Users/jiw2/Library/Application Support/Blender/2.63/datafiles/'
config: '/Users/jiw2/Library/Application Support/Blender/2.63/config/'
scripts : '/Users/jiw2/Library/Application Support/Blender/2.63/scripts/'
autosave: '/Users/jiw2/Library/Application Support/Blender/2.63/autosave/'
tempdir: '/tmp/'
FFmpeg:
'avcodec':' ''53, 60, 100'
'avdevice':' ''53, 4, 100'
'avformat':' ''53, 31, 100'
'avutil':' ''51, 34, 101'
'swscale':' '' 2, 1, 100'
renderer: 'Intel GMA 950 OpenGL Engine'
vendor: 'Intel Inc.'
version: '1.4 APPLE-1.6.36'
extensions:
'GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend'
'GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader'
'GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays'
'GL_EXT_clip_volume_hint GL_EXT_rescale_normal'
'GL_EXT_draw_range_elements GL_EXT_fog_coord'
'GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4'
'GL_EXT_transform_feedback GL_APPLE_client_storage'
'GL_APPLE_specular_vector GL_APPLE_transform_hint'
'GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object'
'GL_APPLE_vertex_program_evaluators GL_APPLE_element_array'
'GL_APPLE_flush_render GL_APPLE_aux_depth_stencil'
'GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip'
'GL_SGIS_generate_mipmap GL_ARB_point_parameters'
'GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp'
'GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map'
'GL_ARB_texture_env_dot3 GL_ARB_texture_env_combine'
'GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat'
'GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program'
'GL_ARB_fragment_program_shadow GL_ARB_fragment_shader'
'GL_ARB_point_sprite GL_ARB_texture_non_power_of_two'
'GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object'
'GL_EXT_framebuffer_object GL_EXT_texture_rectangle'
'GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color'
'GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias'
'GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap'
'GL_EXT_texture_filter_anisotropic GL_EXT_separate_specular_color'
'GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs'
'GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc'
'GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB'
'GL_EXT_blend_equation_separate GL_EXT_packed_depth_stencil'
'GL_EXT_framebuffer_sRGB GL_EXT_provoking_vertex'
'GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422'
'GL_APPLE_vertex_array_range GL_APPLE_texture_range'
'GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_blend_square'
'GL_ATI_texture_env_combine3 GL_ATI_separate_stencil'
'GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod '
APPLE DIAGNOSTIC FILE:
Process: blender [7763]
Path: /Users/jiw2/Downloads/Blender/blender.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: 2.64a (2.64a, 2012-Oct-09, Blender Foundation)
Code Type: X86 (Native)
Parent Process: launchd [125]
Date/Time: 2012-10-12 12:19:49.337 -0400
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 492242 sec
Crashes Since Last Report: 11
Per-App Crashes Since Last Report: 1
Anonymous UUID: 3E538651-236D-4675-A8F5-609691B91079
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x94bf6c5a __kill + 10
1 libSystem.B.dylib 0x94bf6c4c kill$UNIX2003 + 32
2 libSystem.B.dylib 0x94c895a5 raise + 26
3 libSystem.B.dylib 0x94c9f6e4 abort + 93
4 org.blenderfoundation.blender 0x0101b19f __gnu_cxx::__verbose_terminate_handler() + 303
5 ??? 0x78635f75 0 + 2019778421
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x94c9f693 ecx: 0xbfffd54c edx: 0x94bf6c5a
edi: 0x02509db0 esi: 0xa0599b30 ebp: 0xbfffd568 esp: 0xbfffd54c
ss: 0x0000001f efl: 0x00000286 eip: 0x94bf6c5a cs: 0x00000007
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0xffe2a49c
Binary Images:
0x1000 - 0x2e70fcb +org.blenderfoundation.blender 2.64a (2.64a, 2012-Oct-09, Blender Foundation) <D84FB726-CEC9-3EDB-A3C6-51D91A2166FE> /Users/jiw2/Downloads/Blender/blender.app/Contents/MacOS/blender
0x5171000 - 0x519afff com.apple.audio.OpenAL 1.4 (1.4) <CDC6D2B8-3DCA-E511-2250-75567E4C94BD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x51a8000 - 0x51c1fef +libgcc_s.1.dylib ??? (???) <934D1DCF-8903-36CC-8D28-8DE1C5E42C3B> /Users/jiw2/Downloads/Blender/blender.app/Contents/MacOS/lib/libgcc_s.1.dylib
0x8fe00000 - 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0x9001c000 - 0x90096fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x90097000 - 0x900f4ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x900f5000 - 0x900faff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x90125000 - 0x90186fe7 com.apple.CoreText 151.13 (???) <23F359DA-D845-5C50-4DF3-19E858CF2B2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90195000 - 0x901b3fe7 libPng.dylib ??? (???) <5B979A83-8CE7-6BD7-B84C-A2D1119B378D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9073c000 - 0x9073fff7 libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x90743000 - 0x90747ff7 libGIF.dylib ??? (???) <9E51F8ED-83B4-DA41-1E2F-CFA726936A30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90925000 - 0x90aa0fe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90b7f000 - 0x90c3bfff com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x90e8a000 - 0x90eaeff7 libJPEG.dylib ??? (???) <C43FD809-08B6-629D-8980-D7B0ECEA20A9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90eaf000 - 0x911cfff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x911d0000 - 0x911d2ff7 libRadiance.dylib ??? (???) <5F803B4A-B294-BA94-FB68-E8756EE41B20> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x914cd000 - 0x914deff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x914df000 - 0x914efff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x91501000 - 0x91522fe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x918b7000 - 0x918eaff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9190d000 - 0x91921ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x91922000 - 0x9194aff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
0x9194b000 - 0x9198eff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9198f000 - 0x91998ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91999000 - 0x91c93fef com.apple.QuickTime 7.6.6 (1791) <8E56F3DC-725B-0299-7E62-8599CA6EC4C0> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x91cbe000 - 0x91d59fe7 com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x91d5a000 - 0x91d6cff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91f81000 - 0x91f87fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92d02000 - 0x92de2fe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x92df4000 - 0x92e5efe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x92e5f000 - 0x92e69ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92e6a000 - 0x92e90ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x92f06000 - 0x92fbefeb libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x930e8000 - 0x9312aff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x93171000 - 0x93203fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x93204000 - 0x93212fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x93357000 - 0x93361fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93362000 - 0x935c8ff7 com.apple.security 6.1.2 (55002) <3FA54D69-5476-78DD-0AFC-D6697263890E> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x935c9000 - 0x936d5fe7 libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x936d6000 - 0x936d9fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9383d000 - 0x938a1ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x938a2000 - 0x9395bfe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x93a34000 - 0x93a37ffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93a38000 - 0x93a38ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93a39000 - 0x93a40ff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93a41000 - 0x93a8efeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x93aa3000 - 0x93aa3ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x93aa4000 - 0x93b41fe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93b7e000 - 0x93ea2fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93edc000 - 0x93edcff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93edd000 - 0x93f89fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93f8a000 - 0x941fbfef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9423e000 - 0x94256ff7 com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x942da000 - 0x942e5ff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x942f2000 - 0x94335ff7 libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x94336000 - 0x94410fff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x94ae6000 - 0x94b94ff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x94b95000 - 0x94d3cff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x94d3d000 - 0x94d4bff7 com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94d8b000 - 0x94d91fe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x94d92000 - 0x94d92ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94d93000 - 0x94f15fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <50A70082-F800-93D8-1A7C-C95AAB1F352C> /usr/lib/libicucore.A.dylib
0x95601000 - 0x9561dfe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9561e000 - 0x9562aff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x95656000 - 0x95656ff7 com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9566d000 - 0x9579bfe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9582f000 - 0x958dcfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x95a51000 - 0x95a66fff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x95a71000 - 0x95b09fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x95b0a000 - 0x95b3bff7 libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95bae000 - 0x95bd0fef com.apple.DirectoryService.Framework 3.6 (621.15) <F38894EA-2C13-7FC5-C084-94DA0B5B6B68> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x95c15000 - 0x95c5bff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x95e36000 - 0x95e4afe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x95e4b000 - 0x9672eff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x96833000 - 0x96883ff7 com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x968f3000 - 0x96973feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x96974000 - 0x96976ff7 com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x96cbe000 - 0x970f3ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x970f4000 - 0x9712eff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <A6C207E3-7B42-926D-9C93-BE3F50B92496> /usr/lib/libcups.2.dylib
0x9712f000 - 0x97545ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9754d000 - 0x97591ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x975b4000 - 0x976b6fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x976b7000 - 0x97782fef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x97783000 - 0x977f2ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x97936000 - 0x9793aff7 IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x97966000 - 0x97966ff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97967000 - 0x97968ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x97a11000 - 0x97d7cff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x97d7d000 - 0x9856c557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x98594000 - 0x985a1fe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <828CCEAB-F193-90F1-F48C-54E3C88B29BC> /usr/lib/libbz2.1.0.dylib
0x985a2000 - 0x985dfff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x985e0000 - 0x98600fe7 libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x98609000 - 0x98709fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
0x98753000 - 0x98754ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x987ff000 - 0x989c2feb com.apple.ImageIO.framework 3.0.6 (3.0.6) <5BF202E9-730A-3675-4374-E5300BC8ED10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x989f9000 - 0x98a7bffb SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x98e6f000 - 0x98eb3fe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x98eed000 - 0x98f0cff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x98f0d000 - 0x99001ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x99002000 - 0x9900fff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x99010000 - 0x9914dfe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9914e000 - 0x9914eff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x9a372000 - 0x9a41affb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9aacb000 - 0x9ab1eff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9ab88000 - 0x9ab8cff7 libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9ab8d000 - 0x9ab8dff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9ab8e000 - 0x9abdefe7 libTIFF.dylib ??? (???) <E8B31850-BFD4-48E6-B264-A4340CD19929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: Macmini1,1, BootROM MM11.0055.B08, 2 processors, Intel Core Duo, 1.83 GHz, 2 GB, SMC 1.3f4
Graphics: Intel GMA 950, GMA 950, Built-In, spdisplays_integrated_vram
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), Atheros 5424: 2.1.14.6
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS541616J9SA00, 149.05 GB
Parallel ATA Device: MATSHITADVD-R UJ-85J
USB Device: iPod, 0x05ac (Apple Inc.), 0x1293, 0xfd500000 / 3
USB Device: d2 quadra (button), 0x059f (LaCie), 0x1014, 0xfd100000 / 2
USB Device: Hub in Apple Pro Keyboard, 0x05ac (Apple Inc.), 0x1003, 0x5d200000 / 2
USB Device: Apple Pro Keyboard, 0x05ac (Apple Inc.), 0x020b, 0x5d230000 / 3
USB Device: Microsoft IntelliMouse ® with IntelliEye, 0x045e (Microsoft Corporation), 0x0025, 0x3d100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x7d100000 / 2
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8240, 0x7d200000 / 3
FireWire Device: Oxford ATA Device 00, Other World Computing, Up to 400 Mb/sec
Thanks for the report, but it duplicates http://projects.blender.org/tracker/index.php?func=detail&aid=32868&group_id=9&atid=498
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.Oct 15 2012, 3:09 PM
