wavefront (.obj) export
Closed, ResolvedPublicPATCH
i made some changes to the exported maps, im usually in the irc channel (kromar5959) during the week if there are any questions.
1. i changed the specular channel so the color and not the intensity channel gets used for exporting. (map_Ks)
2. added missing map for specular hardnes (map_Ns)
3. made distinction to normal map flag, if its disabled (when using a height map) it exports to map_Disp instead of map_Bump
4. added map_refl
5. added missing emission channel (map_Ke)
in the attached pictures the links between blender and the mtl file can be seen.
applied r3954. with change use_map_color_emission (which is for volumetrics only) to use_map_emit.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Nov 12 2012, 3:04 AM
