VSE preview displays wrong color space
I have a scene strip from a compositor setup, in my VSE timeline. The video clip (8bit source) that comes from that Comp node scene has an expanded color space.
In the VSE I made sure to set the Compositor's Scene strip Properties>Filter>Convert Float to active. The rendered output from the VSE scene (in the UV image editor window) is correct but the VSE preview window is very low contrast and doesn't match.
Attached is an example image of the effect. Looking at the Luma Waveform for both windows shows the effect of raised values. I cannot submit a demo .blend due to no packing function.
WinXP 32bit 2.64.9 r52376
A .blend file can be attached if you put the image and .blend in a zip file, or just upload two files? Anyway, assigning to Sergey.
Fixed in svn rev52433. Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Nov 21 2012, 11:14 AM
