Hi There,
Two commandline bugs
1) the Scene strip does not render for the finishing image
2) Crazy lightness bug rendering images, the first frame it renders is fine, then gets progressively worse
Please find attached a sequence with the bugs & a base image that bugs occur
The command i have been using to render is blender -b C:\sequencetester1.blend -s 6 -e 10 -o "C:\New folder (2)\####.png" -a -F PNG -x 0 , Doesnt matter what frame you start on, it will get progressively worse from that frame.
I am running windows 7, x64 r52422
Cheers
Carlo
Comment Actions
There is another bug with the sequencer aswell (if you want i can create a new bug report)... its to do with the scene strip node.
If you load it up the sequence normally, and you render animation (not render image) from fr6, the scene strip will start at double the framerange... so it will start at 12... starting at frame 100 will render at 200 etc.etc.
Cheers
Carlo
Comment Actions
First issue should be fixed in svn rev52481, second one in svn rev52482. Thanks for the report, closing.
P.S. Just for future -- report bugs in different reports -- that helps a lot keeping track on actual issues if bugs are more nasty than this ones :)
