Crash when delete all or segment from curve with SplineIK
In the attached file, press X and choose delete "segment" with the end two control points selected (should be pre selected), or delete "all"
Delete "select" works fine, it seems, unless you have everything selected.
http://www.pasteall.org/blend/17657 (also attached)
cheers
Tested on current SVN r52489 linux 64 bit.
Official 64bit linux 2.64a
r52290
Joshua Leung (aligorith) changed the task status from Unknown Status to Resolved.Nov 23 2012, 12:19 AM
