Proxies are not built in Sequencer if preview is visible
Steps to reproduce:
1- Launch Blender
2- Switch the main view to a sequence editor. Press the 3rd choice for sequencer view (sequencer + preview)
3- Load any movie file.
4- select it, and Press N
5- in the view properties, under Proxy/Time Code: enable proxy timecode.
6- In the strip menu invoke "Rebuild Proxy and timecode indexes"
Result:
the operation ends immediatly. The console prints:
"Canceling proxy rebuild on users request..." a very cryptic message that is also not true ( i did not request this cancellation!!!!)
6b- In the seqncer header, select Sequence in the view options (turn off the preview)
7b- repeat 6.
Result:
This time it works!!!!
If it is not for some reason, possible to do this with the preview open, a less cryptic message should pop up and inform the user they need to turn off the preview.
GNU/Linux (Fedora 17) 64 bit, Intel CPU, nVidia GPU
Fixed in svn rev52631. Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Nov 28 2012, 10:36 AM
thanks sergei! this should help the user friendliness of the sequencer :)
