Change Path/Files problem - selected strip directory doesn't work
Hi, I have a problem with sequencer in Blender 2.65 test build. Until this version, changing Path/Files (C key after selecting an image strip) worked really really good - when you had a strip selected, after hiting C and selecting Path/Files you were directed to the directory of the selected strip. Now it doesn't work everytime.
I've attached a zip file containing sample blend file and a directory called "render". Let me explain my workflow using Blender for video editing... As you can see in the example files, the "render" directory contains folders for 2 scenes: scene1 and scene 2. Each folder contains 2 subfolders with different versions of each scene: v1 and v2. Now, open the change_files.blend file and the scene called editing. There are 2 strips containg files from scene1/v1 and scene2/v1. What I want to do is to change files in those strips to newer versions (v2). When you select each strip, hit C, select Path/Files, it seems that it works right - you are redirected to folder with those images.
But... When you change one of the strips and then you want to change the other strip, you are not directed to the right folder - you are directed to the last used folder instead.
To reproduce bug:
1. Open change_files.blend
2. select first strip, hit C, select Path/Files
3. go to render/scene1/v2 folder and select all the files A, then confirm with Enter
4. select second strip, hit C, select Path/Files
5. BUG! you are directed to previously selected folder instead of the one containg images from the strip
thanks for the concise report - makes our job easier,
fixed r52788.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Dec 6 2012, 3:39 AM
