2 Meta Strips occupies same place in timeline
It is possible for 2 meta strips (in this case 2 versions of same meta strip), can occupy the same frames as each other.
After (K-key)cutting a meta strip I (tab) edited the first (left side meta strip) to be longer. Stepping out of edit mode I found that they both occupied the same space.
I was trying to move audio in the meta strip along so that it would not be heard. I really just wanted to delete the audio but that made the meta strip 0 frames long. That could be another bug.
And when I duplicated the overlapped pair of meta strips the resulting duplicate appears to have no strips inside it!
I have included both bugs in the .blend.
b2.65 r52860
Win XP
Would check on it a bit later.
Fixed meta strips overlapping in svn rev53574. Wasn't able to reproduce other issues you've mentioned, please test fresh builds and if you'll have more issues let me know.
For until that considering the bug resolving and marking report as fixed.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Jan 5 2013, 9:04 AM
