Solidify - Material index problem
Win 7 64bit, GeForce GTX 550Ti
error in svn r53476
also in official 2.65.0 (r52859)
don't know if it worked in previous versions.
There are two problems actually, but they seem closely connected.
1. Objects with Solidify Modifier, which are copied, lose the Material Index Offset in that modifier.
2. After copying/linking the Solidify Modifier itself to another object, the Material Index Offset is reset to 0.
Open the attached file (solidify.blend)
In the file, there is the object "Plane" with materials "yellow", "blue", and"red" assigned to data,
and a solidify modifier with Material Index Offset = 1, Rim = 2 (which makes the back surface blue, and the rim red).
There is another testing object called "Object" with the same three materials and no modifiers.
To recreate problem 1:
Copy (shift D or alt D) "Plane".
The Material Index Offset and Rim are reset to 0 in the new objects (all other modifier properties are maintained) so the rim and backside become yellow.
To recreate problem 2:
Select first "Object" then "Plane".
In the menu Object > Make Links > Modifiers.
The Solidify modifier is properly copied to "Object", except that Material Index Offset and Rim are reset to 0 again and the object remains yellow.
I was planning to write about the same thing. I noticed this some time ago and checked that it never worked properly.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Jan 4 2013, 9:17 AM
