Blender crash on out of range input for Subdivision Surface
Win 7
ATI HD 4600
2.65a (Error)
Do not have other version installed to test if it works
Blender crashes when entering large value in Subsurf Modifier's View field.
1) Open default blend file with cube
2) Go to Modifiers tab
3) Add modifier
4) Subdivision Surface (under Generate column)
5) Click centre of "View" under "Subdivisions:" label to input custom value
6) Enter large value (e.g. 100) and Blender crashes. Please note that max allowed value using increment buttons is 6, so this is probably a low priority bug
Cheers!
Blender doesn't handle cases when you use more memory than a system can provide. For anything you do, a user is supposed to keep a good eye on used memory.
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Jan 10 2013, 3:21 PM
