Multiple systems, Windows 7 64 bit
r53999 and later is where I have noticed the error. Do not know where this started, but r52864 is correct.
No alpha is being rendered in Blender Internal render. RGB and RGBA give the same result (no alpha channel)
No .blend needed. Load default cube, render with blender Internal with RGBA checked. There will be no alpha.
Comment Actions
This was an intentional change, read here for more details:
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.66/Image_Transparency
Previously you could save this way with an alpha channel, but the result would in fact give some incorrect color fringing on edges if you didn't also set the shading alpha option, which is now required to be set.
