Crash opening file containing translation node saved before rev54235
If you try to open the attached file with a blender revision of 54235 or later, it will instantly crash. This is because the file contains a translation node and was saved before rev 54235.
If I tell blender not to load the UI from the file then I can open it, but when I try to render or go to the node editor it crashes.
Note: rev 54235 introduced "Wrapping mode for the "translate" compositing node" http://projects.blender.org/tracker/?func=detail&atid=127&aid=33999&group_id=9
Tested on blender rev 54235. MinGW 64 build.
Windows 7 64bit
4GB ram
NVIDIA Quadro 1600M
T9500 Core 2 Duo @ 2.6 GHz.
Was about to submit the exact same bug report.
Opening a file that contains a Translate node made before the last wrap-mode addition (like 2.65a release), will crash.
Ubuntu 12.10
Created node storage for older blend files.
Fixed in revision 54279
Monique Dewanchand (mdewanchand) changed the task status from Unknown Status to Resolved.Feb 3 2013, 4:40 PM
Not fixed for my setup :(
Check attachments, or this file:
http://pasteall.org/blend/19248
Try unhidding the Translate node. Crash.
Hi,
Updated fix in revision 54304
Sorry about that.
And followup fix for that in SVN 54331.
