Hi,
Blender crashes when I try to go into Edit mode, after applying Decimate or Remesh modifier.
It crashed with 2.65 and latest SVN.
Debian AMD64, AMD HD6850
1. Add a UV-Sphere
2. Tab into Edit mode and select some faces (but not all)
3. Tab out of Edit mode, add a Decimate (or Remesh) modifier.
4. Set Decimate parameters to: Collapse with Ratio 0.1 (or Remesh parameters with: Octree Depth=2) (Just to be sure that many faces get eliminated)
5. Click "Apply" on the modifier
6. Now Tab into Edit mode again and Blender should crash immediately.
I think Blender tries to restore the previous selection of the faces but fails.
Comment Actions
Can't redo r54283
Could you upload a blend file setup just before you press 'Apply' on the modifier?
Comment Actions
This would only crash if you selected faces with high index values, explains why it was random :)
Interesting nobody discovered this before, fixed r54292.
