--- Operating System, Graphics card --- Ubuntu 12 10 64 Nvidia Geforce
--- Blender version with error, and version that worked --- 2.65.9 54330
see: bug Sec 2.blend
There are 3 Scene: Scene.000, Scene.001, Scene.002
in Scene.001 and Scene.002 There are a color strip with transparency (Video Editing)
in Scene.000 Video Editing space were added Scene.001 and Scene.002
When you render in Scene.000 not render the color strip effects
see: bug Sec 1.blend
Same with image strips, img_1.jpg in Scene.001 and img_2.jpg in Scene.002 ( Attached img_1 and img_2)
When you render in Scene.000 not render the image
And: when there is not a camera defined in 3D space on any Scene does not allow working with strips
See .blen atached files
Comment Actions
Thanks for the report, but it's not a bug. Sequencer was never ever designed to render sequencers recursively and it only worked in some cases and failed dramatically in other cases. Now recursive sequencer is disabled explicitly.
Comment Actions
Thanks for your great work, regarding the bug, I think You Should then specify in the "add" menu option instead of "Scene", "3d space" or something similar. Currently the menu option "Add Scene" in video editing space is misleading.
