cpu: amd athlon 64 3800
ram: 1024 mb
gfx: ati radeon xpress 1150, 512 mb
os: windows xp pro, service pack 3
error is in both 2.63 and 2.66
setting map uv node alpha to 0 does not always produce a solid white alpha channel.
see attached images. if we enable a set alpha node after the map uv, then the resulting alpha can be fully white, but we shouldn't have to this step if the map uv's alpha worked properly.
attaching blend file made in 2.66, compare the map uv alpha results with the set alpha node muted and unmuted. surely a map uv alpha value of 0 should produce the same solid white alpha channel? but currently it still mixes in some alpha.
If attaching doesn't work you can use http://pasteall.org/, the system on this bug tracker tends to be a bit unreliable.
thanks and i managed after a couple of attempts to attach the blend file. i hope one of you guys can check it out soon.
why is the status of this ticket still "Incomplete" when i uploaded the .blend file as requested?
There are a lot of reports we have to handle every day, that is all. Changed to "Investigate" now.
Hi Ratty,
this is not a bug. It is the way the node works. The apha setting is a threshold setting, not a set alpha option, more information at:
http://www.blender.org/development/release-logs/blender-243/composite-uv-map-displace-id-mask-and-z-combine/
Jeroen.
