Boolean operations strange behavior
This Issue is in versions: 2.65, 2.64 (Windows / Linux)
Worked as it should in: 2.61
Seems like a bug in Carve library
Base object is vanishing when modifier object has similar size.
Load python script and see what's happened right after second commented line.
Unfortunately, this is a known issue is Carve library which was forwarded to it's developer. Thanks for the report, but there's not so much we could do from blender side for now.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.Feb 19 2013, 1:06 PM
