Linux Mint 14, 32 bit
01:00.0 VGA compatible controller: NVIDIA Corporation G94 [GeForce 9600 GT] (rev a1)
I build a mesh that blender will not render no matter how I try to make it work.
I did strip everything from the mesh and left a simple stretched cube but still I don't get render.
I am attaching both the original design and the stripped one.
NOTE: In the original (made for testing purposes) you can find vertex groups so you can see the various faces
that I created. All the "tools" I used are: Stretch, Grab, "F" for making faces, Duplicated some vertices and moved them around.
IMPORTANT: market.blend is the original file, and try2.blend is the stripped one.
Just hit render. It will not get rendered!
Comment Actions
Ignore this bug. It is invalid. The problem was that I had enabled the Object->Duplication->Face. When set to Object->Duplication->None works.
Thanks to ideasman for the info.
