win32
r54698
Fill Rim option seems to add unnecessary faces diss-accordingly to Vertex Group's limitation
open blend
slide Inner or Outer Crease in Solidify
turn off Fill Rim
you'll see what I mean
Comment Actions
Solidify always works on the entire mesh (like "select all, extrude anything along the normal"). The group only controls the thickness. If vertices are not within the group, then they will still be extruded, but the extrusion distance is 0 (weight=0). This is not a bug. This is how solidify works.
Comment Actions
yeah, I agree... But parts of mesh in this case are separated. It's not a problem. I just have thought it's a bug.
