Plane with Alpha-Textur does not render correct inside a smoke-domain
Win7 64BIT
Blender 2.66
Hi! Im making a smoke-simulation where a plane with texture is inside the domain-box.
When i use a texture with alpha-chanal the smoke behind this plane will not render.
When i move the plane outside the domain, the smoke behind is rendered correctly.
This means: AlphaChanel inside a domain-object does not render.
Greets,
Dennis Fassbaender
As i can see, this only happens with Z-Transparency! Using RayTracing works. SORRY!
Using RayTracing the main-background is not rendered correctly- check it with a gradient as background!
In Blender, ztransp, volumes, solid faces, halos, sky, strands, ... is all rendered separately and combined *after* it was done. The default way it combines you cannot control, that's why we allow users to set this to individual render layers so you can composite it together.
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Feb 26 2013, 3:21 PM
Dear Ton,
i checked this.
Used two different layers and combined them in different ways in the compositing nodes.
Ive tryed MIX, Alpha- and Z-combine. Tryed different combinations of on/off switched layers.
Using Layers doe not help!
I found out that the "Paper Sky"-Option in the world settings caused this problem using RayTransp!
Disabling it, and averything is rendered well!
Just the ZTransp-Option does only work outside of a adaptive domain.
Beween the DomainBox and the AdaptivDomainBox is okay, too ;).
The bad thing is, that transparent parts of an alpha texture can only be displayed in the 3d-view while ztransp is enabled.
Regards,
Dennis
