The issue is reproducible with windows and linux. No other OS available for testing
It works properly with Blender Release 2.65a
It does not work with Blender Release 2.66. I have also tried the RC, with the same bad result.
It seems to me, the problem is connected with the new "Image Transparancy".
In VSE, If you SUBSTRACT one picture by another, the the result is all black, instead having a new calculated image.
In the attached .7z file you will find a .blend file, which shows the issue. You will also find a good_case.png showing the expected result and a bad_case.png showing the issue. The only difference between Blender Release 2.56a and 2.66 is the disappeared "Premultiply" button. If I check this button in 2.56a, then I see the same bad result as with 2.66.
Comment Actions
This was actually a display issue -- sequencer in 2.66 was actually displaying RGBA image, and in previous versions it was more like RGB image.
I've added a way to display either RGBA or RGBA in the sequencer in svn rev54904 and think it shall solve your issue. There're still some improvements to be doe, but that change shall make sequencer behaving closer to render result in image editor.
Thanks for the report, closing.
