Win7 x64 Lenovo Y580 using Intel HD4000
--- Blender version with error, and version that worked --
official 2.66 and recent trunk 54991
when i accidently created a loop inside a compositor and than cut it with ctrl+left mouse drag blender crash
i wouldnt crash when unplugging such a connection
FACTORY SETTINGS:
Just go to node editor.
- use Nodes.
- add 2 mix node into node tree
- feed second mix node output to the first mix node input creating a loop visualized as red connection
- cut red connection with ctrl+left mouse drag
- CRASH
- instead of cutting just unplug red connection to avoid crash
No crash here with SVN 54991, Windows 7 x64.
Maybe I did something wrong, in such cases also attach an example blend file, so we only need to cut the line. :)
No crash here after cutting the red line. Windows 7 x64, SVN 54991.
So same OS, same Revision. Not sure why it works for me but not for you.
Maybe Jeroen can check on a Linux system? Assigning to him.
4 tests by 4 developers, no one could reproduce it.
@Czarek: Can you test this on another computer? Or maybe update GPU drivers?
No crash here linux64 2.66 and trunk release build.
During development there were some crashes here (april-june 2012) but has been solved. I will close the report for now. there is also a way (but have never reproduced it) that a specific trunk version created wrong links, that made a crash but that is not with a recent version. Please open again when it can be reproduced.
Thanks for the report!
Ehh Firstly SORRY i had two beers and ... never mind :)
Blender Crashes when doing reroute (Shift+LMB drag) on looped connections not cutting.
