Boolean Modifier bugs with plane mesh?
Windows XP
Ati Radeon HD 4800
Version 2.66 - r54697
First bug:
In Object mode:
1. Add a cylinder mesh;
2. add a plane mesh;
3. boolean modifier on plane mesh
4. operation "difference", object "cylinder" then apply.
The result is not a "perforated" plane, as expected. See attached figures.
Second bug:
Boolean modifier between two plane (any operation) crashes the system. Try:
In Object mode:
1. Add the first plane mesh, grab and scale it;
2. Add the second plane. The planes are of course at the same z-coordinate (z=0);
3. Select first plane, add a boolean modifier (any operation, for example "intersect"). Object: the second plane
...the system crashes.
Best regards.
Thanks for the report, but it's not a bug. Since 2.62 (Carve library integration) booleans requires closed manifold meshes, i other cases behavior is undefined.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.Mar 7 2013, 8:20 AM
