MultiLayer OpenEXR (from Maya) - passes lost in Compositor Image Node
Win64
Rev55162
Blend file with MultiLayer OpenEXR image attached.
Image node with MultiLayer OpenEXR (from Maya) doesn't show passes (ao, specular, shadow, diffuse, etc).
These passes can still be viewed in Image Editor.
Worked fine in 2.65
I've commited two fixes:
- svn rev55210 fixed using uninitialzied layer and pass names were used, which seems to be a reason why sockets generation failed.
- svn rev55211 fixed issue with non-updating sockets when changing image datablock used in Image node.
To fix file you've attached, simply choose image from a dropdown list again and i'll re-generate all the sockets. In the future this issue shall not happen again and no weirdo tweaks will be needed.
Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Mar 12 2013, 12:09 PM
