Speed controll affects on wrong video length (after sperate video)
windows 7 sp1 64bit.
AMD Radeon HD 7700 Series
Blender 2.66.1
r 55365
2.49b is correct both video and images.
Just affect wrong. No error. No waring.
1.switch sequencer. import any video OR images.
2.seperate video/images.
3.add speed controll.
4.alt+a you'll get it.
I've attached a image to explain that. Hope it is better than explanatory note.
Thanks For your hard works!
I bet it's not a bug. It happens for the following reasons here:
1. You are using K, which is for soft cut;
2. "Stretch to input strengh" is toggled.
Just try to figure out how speed control works, which can "solve" this, for sure. :P
FYI:
http://wiki.blender.org/index.php/Doc:2.6/Manual/Sequencer/Effects#Speed_Control
Correction: I mean "Stretch to input strip length".
Hi Leon, thanks for the help with investigating this!
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Mar 19 2013, 7:48 PM
Ops. That my mistake.
Cuz 2.6 have the different default value With 2.4.
Sorry For That !
Thanks for your reply.
Suggestion .
If we can extend the speed control affect on a "hard cut".
Change movie speed will be more easy understand and controll.
Especially when make the music video.
Sorry. I looked around in the head bar. then Found the Hard Cut (shift+k).
