Displace modifier doesn't work with node-editor created textures
ArchLinux 3.8.3-2-ARCH x86_64, NVIDIA Corporation GF116 [GeForce GTS 450]
2.66a x86_64
The displace modifier works with textures created in the textures tab of blenders properties-editor, but does not accept textures created with the node-editor. (This makes scaling, rotating, etc. not applicable)
It's a known limitation, the texture nodes don't support this, nor can they... this node system is high on the list to get removed even (loads and loads of issues, nobody supports it).
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Mar 23 2013, 5:14 PM
