Windows 7 x64, Radeon HD 2600 512mb, RAM 4gb
blender 2.66a, -
Cycles CPU engine doesn't render all the items of object which contains Array and Subdivision Ssurface modifier. Few last items are missed.
object - exported from 3Ds max 2009 x64 to .obj with blender settings after imported to blender cleaned up and has been saved to .blend. And then Appended into scene.
Memory peak at 700-800 mb.
After applying works great.
I've found what was wrong, The object's modifier stack has two: top Subdivision surface (view=0; render=2), bottom Array (with Relative offset parameter)
The problem was that I had difference between viewport (solid and rendered) and render results, because of Relative offset parameter takes to account different parameters for viewport and render.
So it renders all the items properly but closer to each other. It's more tricks of using modifiers than bug.
Sorry for false alert.
Don't think it's a bug. Relative offset depends on object's bounding box, which is different for different subdivisions levels. You can use constant offset in this case. Or use object offset.
Thanks for the report, but that's more a specific of particular modifier stack.
