WinXP and Linux Ubunt
Is not working with official release blender 2.66 and 2.66 r55662
works with official blender release 2.65a
I am using several functions in the sequencer (ADD, MULTIPY, SUBTRACT) in combination with PNGs and a Video. The result should have a white oval formed frame. But the frame is black
I attached a .blend file, which can be used for reproducing.
Comment Actions
I had a look at the sources of blender and then I found something, which lead to my awkward outcome.
Attached is a PDF with explenation, what I have changed to make it work. I hope, it is helpfull.
Comment Actions
In the meantime, I had also a look at do_mul and do_add. After changing them, too, all my issues were solved. I had also some issues with rendering (animating) into MPEG.
Attached is the new seqeffects.c I am using now. I marked all changes I have done with //ICHANGED. So it is easy reproducable, what I have done.
The changes seem not to have a global impact.
Comment Actions
Fixed in svn rev55924. Thanks for the report and your investigation (used different approach tho).
