win64 r55709 builder.blender.org
Check the attached file.
The modifier should make a hole in the bigger object ("Difference" operation) but the result is incorrect.
The "Intersect" operation fails as well.
Only "Union" seems to give the correct result.
Note: click on the eye to enable the modifier for testing (disabled on startup so you can see the scene)
Comment Actions
There is no bug here, just your normals that are switched (directed inwards the meshes)…
When you have a boolean issue, always check your normals, 90% of problems are caused by misdirected normals!
