Spotlamp with buffer shadow + object without "Cast buffer shadow" = artifact
MacOSX 10.8.2 (12C60), 2.26 GHz Intel Core 2 Duo, 4 GB 1067 MHz DDR3 RAM, NVIDIA GeForce 9400 256 MB
2.66.0 r54697 has error
A spot lamp with halo and buffer shadow combined with an object that doesn't have "Cast Buffer Shadow" (Material RNA: use_cast_buffer_shadows) has a plus-shaped artifact (possibly a triad) in the render view. Enlarging the value of the spotlight's "Halo Step" value (Lamp RNA: halo_step) enlarges the shadow. Setting spotlamp to "No Shadow" or "Ray Shadow" alleviates issue. Checking "Cast Buffer Shadow" alleviates issue.
Open file, F12. You will see a crosshair on the letter "B".
Switch the object's material to "F WithBufferShadow." Press F12. The artifact is gone.
If you want, go to the lamp ("Spotlight") and increase the Step value to get a bigger crosshair.
Also attached: images with and w/o artifact.
Confirmed - this is most likely a floating point precision error, the code tries to intersect the view vector with the lamp cone, and there it exactly looks into the cone tip...
The code that was sampling the shadowbuffer exited too soon (for ray going perpendicular to buffer it should take at least 1 sample).
Fix in svn. Code from 90ies, whoa ;) Thanks!
Ton Roosendaal (ton) changed the task status from Unknown Status to Resolved.Apr 18 2013, 6:27 PM
