Linux (LFS)
Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
Blender 2.66a
possible spotlight bug ?
I was following this tutorial : https://www.youtube.com/watch?v=Jx830_W7MzY
and possibly discover a bug with spotlight : see this video I made : http://youtu.be/XsQZ4cKxTCk
I was animating the spotlight along y axis and you can see "extra" lighted area (under the window) showing in the video.
I will attach the blend file or you can follow the tutorial and recreate it yourself.
I haven't turn on halo or anything just simple default spotlight.
BTW, I have already try applying the solidfy modifer, still same problem.
The geometry is fairly simple and I have double checked all the normals.
Comment Actions
Reducing the `Bias` value of the lamp resolves the problem, but when rendering this works as expected.
This could be a bug in GLSL's use of the bias value?
Assigning to Brecht.
Comment Actions
It's because GLSL only implements the "Classical" shadow buffer type, not "Classical Halfway". If you turn on the former for rendering you'll see the same issue. We only support a subset of the render engine features in GLSL, this is one such case. All I can suggest is to tweak the Bias value.
