Blender Crash rendering Curve/Text object + SubSurf Modifier
Windows 7 64bit, GTX 560ti
r55918 to r55983
This file renders fine in older (2.66a, 2.65a), but it crashed newer SVN builds every time F12 is pressed.
It may not a problem of FreeStyle, because it crashed with or without it.
Just press render/F12 on the file.
File is here >> http://www.pasteall.org/blend/20758
It seems that Bezier Curve + SubSurf Modifier causes the crash.
Campbell, can you look into it?
The other types of curve objects and the text objects also cause the similar crash when using SubSurf Modifier...
Confirmed on OSX with/without FreeStyle. This recently started crashing a file I've been working on for a long time. I isolated it to the the same problem area, (curve + Array Modifier) and came here to post the bug.
Fix in svn, thanks for the report.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Apr 15 2013, 7:45 PM
