Fedora 17 64Bit
Intel hd 3000
56047svn debug
Date Noticed: 18th April 2013
I am using Blender SVN version 56047 on Fedora 17 64Bit Linux.
I am not sure if this is a bug or not but.
In the attached Blend file If you render the current scene you
will see a tube being dipped into a water material.
Notice that the tube gets bent by the ior
when it is rendered. If I select the water material and set its
alpha value to 0, the ior also seems to stop. I doesn't seem to
do this with other materials, just this one.
So just in case this is a bug in this material or a bug with Blender
I thought I would post.
I have attached the Blend file and my system-info.txt file.
Terry Wallwork
Comment Actions
That was an old optimize in the code, to allow alpha zero faces to be excluded from render completely. In this case it shouldn't :)
Fix is in svn now, thanks for the report.
