win64 builder.blender.com r56081
When instancing an object using a particle system generator, the resulting duplicates are rotated 90 degrees on Y axis.
The original object as well as the generator are not rotated or scaled.
Check the attached file.
Comment Actions
Changing Velocity --> Emitter Geometry --> Normal to 0.0 and Emitter Object Y-axis to 1.0 makes the generated objects to orient correctly.
However this should not happen since Z-axis would be the correct direction.
Comment Actions
Hi,
I'm sorry, but this is an old and long outstanding issue in Blender. There's six reports collected (including yours) here:
http://projects.blender.org/tracker/?func=detail&atid=498&aid=32340&group_id=9
Particle code is "orphaned" in Blender... we need new maintainer.
