Curve build modifier
Windows 7 64 bit, NVIDIA Quadro 1000M
error - 2.66.1
worked - 2.57
A build modifier on a bezier or NURBS curve, or a path, builds in an unpredictable, apparently random order. On a mesh it uses the vertex order, as expected. Checking "random" changes the order to a different random sequence. In 2.57 it built sequentially from the start of the curve/path.
1. Add bezier curve
2. Add build modifier to curve
3. Scrub through animation
It's not as much a bug than a limitation of constructive modifiers applying on a curve. The thing is -- edges are mainly automatically generated in this case and their order is not so much determinate.
Campbell, could you think of cheap way preserving order of existing edges in CDDM_calc_edges/BKE_mesh_calc_edges? If not would suggest calling this is known limitation of constructive modifiers on curves.
fixed r56204,56205.
With no polygons it doesn't recalc edges at all, with some polygons, it extends the existing edge array but keeping them in order.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Apr 22 2013, 2:30 PM
