Linux x86_64, ATI HD6950.
Blender 2.67 RC1 with error.
Mesh edge crease loosed after bevel mofidier.
Comment Actions
I believe revision #58076 (this is after RC1) fixes this. It is not clear where the crease should be copied to; the fix I made copies it to the two outer edges of the beveled edge.
Comment Actions
Fix that you made work well! But i think crease of edges neighboring to beveled edge shouldn't be lost too. And crease of edges between beveled edge ends shouldn't be equals zero.
May be additional checkboxes in Bevel modifier UI needed to allow setting of it's behaviour?
Comment Actions
I attach example blend file:
http://projects.blender.org/tracker/download.php/9/498/35109/26533/edge_crease_after_bevel_r58103.blend
and picture with explanations about problem edges:
http://projects.blender.org/tracker/download.php/9/498/35109/26534/edge_crease_after_bevel.png
