--- Windows 7 64 bits ultimate - i5 2550k - gtx560ti ---
--- 2.67RC1 : R56271 ---
--- Hi !
Without using the new render border function, the backdrop don't show anything, neither the image editor on viewer node.
Still using the render border function, sometimes it works, sometimes nothing...
--- here it come a little test scene to show the bug. ---
Regards.
Myke
Works fine here.
I opened the file, rendered via F12. Image shows fine in Image Editor (Viewer Node mode) and Backdrop in Compositor shows as well.
SVN 56376.
Workaround is to click on the viewer node first, then press render.
Lukas, I'm guessing it's caused by this commit, does that need a version patch?
http://projects.blender.org/scm/viewvc.php?view=rev&root=bf-blender&revision=56271
Yep, it's working if i click on the viewer node first before rendering .... just a little bug so...
Yes, this probably would just need initialization of the scene->nodetree->active_viewer_key in do_versions. Selecting a viewer node is one way of updating this key. Note that active_viewer_key is just a weak reference (nothing harmful happens if the key is invalid), and it's not 100% reliable (e.g. renaming a group node may invalidate the key). Not sure if a do_versions is necessary? Ton wants to keep compatibility code to a minimum ...
I think a version patch is definitely necessary, node setups with a viewer node should keep working.
Could be the same as my bug 35144
http://projects.blender.org/tracker/index.php?func=detail&aid=35144&group_id=9&atid=498
Fixed this in SVN. Note that for some reason the viewer node in your test file is not associated to the viewer image, you need to first select it once, but then it should work again after saving/loading. Thanks for reporting.
