VSE - speed control Trim duration (soft) end reset to 0
Windows XP / Linux Ubuntu
2.67 RC
When moving a strip in VSE, Speed control effect Trim duration (soft) end is automatically reset to 0
- Open attached file
- Select image2 strip ( on track 3 ) ( should be already selected in .blend )
- Press G to move image2 strip --> Speed control ( on track 2 ) soft end is automatically set to 0
Don't hesitate to contact me if you need more information
Such kind of trimming is not possible and it was disabled for until hacks added for EDL import in svn rev53509 :) Basically, effect is always expected be the same length as it's input.
Will add some update callbacks to RNA properties, so editing them manually wouldn't lead to crappy situations (G-key behaves correct btw).
Fixed in svn rev56467. Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.May 2 2013, 10:25 AM
