osx 10.8.3, macbook pro 6.2, 8GB, gt330M
r46458
(built on 10.8.3 with:
CC = 'clang'
CXX = 'c++'
Node Filter - Filter - Laplace
Color and Alpha Channels are reversed.
Color is emtpy and Alpha contains Color Channel
Add Filter - Filter
set to Laplace
look at Color/Alpha Channels
Comment Actions
Sorry for the "broken" in title, thought first it was completely broken, until i found alpha channel, then forgot to change title..
Comment Actions
The filter is actually working correct, it's unlike the other filters in that it provides sort of a difference between neighbouring pixels that you can then add or subtract from the original, or use in some other way.
I'm not sure how useful these filters are in practice or if perhaps it would be more user friendly to put these in separate nodes, but for now seems to be working as intended, so closing report.
