Blenders colour wheel in the compositor doesn't show the correct colours, but still seems to work
Mac OS X Mountain Lion (Hackintosh). GTX580, GTX 560Ti, Intel 4000.
GTX580 and GTX 560Ti are used for CUDA rendering. Intel 4000 is hooked up to the display.
2.66.6 (r56271) and just tested on latest build from buildbot (2.66-r56501). Both produce the same error.
Any project I open, old/new, shows any colour wheels as can be seen in the attached image. Moving the point on the wheel seems to work as normal, so it just appears to be a problem with displaying the colour spectrum on the wheel. Every now and then when I zoom in/out on the compositor, the correct colours flicker on for an instant, but then it goes back to what can be seen again.
I've just recently switched from using my GTX 560Ti for driving my display to the Intel 4000 graphics and I believe that's when I started seeing the problem. To test this, I just switched back to one of my GTX cards for my monitor and the colour wheel is displaying correctly again. So, it looks like it's a problem with the Intel 4000 internal graphics.
I realise that with using a Hackintosh, I could have created the problem myself by not having the correct boot flags/kexts, but all my other applications seem to work fine with the Intel graphics.
Open any blend on a machine using Intel 4000 graphics to drive the display and add a node with a colour wheel.
This is an error with the opengl drivers, we've had this reported about some intel cards before.
You could try update drivers to fix the problem.
closing.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.May 5 2013, 7:13 PM
