Ubuntu 12.10 GeForce GTX 260
tested on official build 2.67 and r56534
Can't use "from dupli" method on particles with object type of visualization, then scene linked to other.
I think, it because texture coordinates lost.
In images you can see
1. cubes in original file - colored by gradient, using uv-layer of sphere.
cubes in new file, linked from first scene - solid gray, no UV-layer (if texture is lost they must have diffuse color).
I create a simple scene to reproduce the error. cubes duplicates on sphere, by particles. Gradient texture set color of cubes, using "from dupli". This objects are grouped in lib.blend and linked to test.blend
1) open lib.blend and render - You will see, that cubes have different colors
2) open test.blend and render - now all cubes sold
PS Sorry, if my English is so bad!
Comment Actions
Confirmed - the feature "Inherit texture coordinates from duplicator parent" is not working.
