Windows 7, x64, gtx 580
r56837 has error
When the modifier visibility is turned off from viewport, playback speed in the movieclip editor is normal (no viewport visible)... when the modifier visibility is turned on for viewport... the playback speed is significantly reduced. I have a feeling it is trying to load in the smoke for every frame even if the viewport isnt visible
Step 1. Open up a blender
Step 2. create a smoke simulation which is complex and bake it out to a file
Step 3. change 3d viewport to movie clip editor
Step 4. open movie in movieclip editor and press play
Step 5. turn smoke visibility off from viewport and notice the speed difference on the framerate.
Comment Actions
This is correct, we should optimize this once but currently the animation/depsgraph system is not smart enough, it updates all objects regardless if there is a 3D view open or not. Not considered a bug.
