Operating System: OS X 10.8.2
Processor: 2.7 GHz Intel Core i7
Graphics Card: NVIDIA GeForce GT 650M 1024 MB
2.67 (it's the only version I've ever used), downloaded from the blender website.
Switching the screen layout from a command line invocation of blender causes a segmentation fault.
Run the following command:
blender --python crash.py
The crash.py script is only these two lines:
import bpy
bpy.context.window.screen = bpy.data.screens['Scripting']
If you start blender and run this from the python console, it works fine, it's just the command line version that doesn't work. It also does not seem to crash if --background is supplied.
Comment Actions
Well obviously screen layouts shouldn't be switched without UI... should be easy to ensure it gets ignored.
Comment Actions
That fix is not working, i also don't think handlers should be freed there.
See this report:
http://projects.blender.org/tracker/?func=detail&atid=498&aid=35481&group_id=9
I'll check this crasher too, maybe I see where the issue is.
Comment Actions
Hrm, I don't it to crash, but also not doing anything (it should set the screen to scripting?)
