Weight paint with mirror modifier does not accurate represent bone influence
Windows 7 (on an iMac), Mac OS X (Macbook Air)
2.67a with error. Don't remember when this last worked as expected, but I'm sure it did at some point.
When a mirrored mesh is parented to an Armature using automatic bone weights, deform weights are set correctly. However, when viewed in weight paint mode, display shows weight paint values also mirrored, incorrectly representing the bones' actual influence on the mirrored mesh.
See attached image. Create mesh, add mirror modifier, add armature, parent mesh to armature with automatic weights.
After this commit, weights do not show on an object which has a mirror modifier at all, *unless* there is an armature modifier and armature set in the object field.
I did not know whether to make a separate report or not.
Cheers
Attached a file which doesn't show weights when the armature is disabled, will check on a fix.
fix for fix r57419.
If there are any further problems, best open a new report.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Jun 13 2013, 2:34 AM
