windows 32 bits
video G31 G33 intel
did discussed this in python forum and it might a bug with Bmesh
included file with script in text editor
run the script then in add menu mesh select weave at bottom
change the variable in tool pro panel called warp number
before last button
as you increase it at 3 then it crashes saying that bmesh was lost
it does work on the first loop but on second one there is an error on the remove doubles for Bmesh data
thanks
happy blendering
I would guess the problem is accessing mesh data after its removed, however this isnt crashing for me, will check further.
Ricky: there is no such "2.67b SVN". You mean, the binary we released on blender.org?
yes i use the official release 2.67b from blender org
just got latest SVN i57299
and same error
it looks like when it goes first time in loop it will erase doubles
but the second time it tells me that there are no data
error is
zz1.py", line 285, in execute
File "C:\Users\RJ\0blend25\00aaaujune20121\ropemaking2\weavescript1\zz1.blend\
zz1.py", line 51, in adddata1
ReferenceError: BMesh data of type BMVert has been removed
it looks like after doing a remove doubles it does not have any data left for bmverts!
it should be possible to remove doubles any number of time even if there are no doubles!
thanks
Checked the script.
- line 203 adds to 'verts'.
- line 282 removes doubles.
- line 285 passes 'verts' to adddata1.
- line 51 does an invalid access.
You need to re-create 'verts' list after remove doubles since it contains data that was removed.
closing.
